Choose the Olight ArkPro if you regularly switch between lighting the ground at your feet and picking out a sign or gate further away. It has two dedicated white beams and accepts a USB-C cable as well as Olight’s magnetic charger. The Arkfeld Pro is the lightest of the three and covers everyday white light, UV and green pointing. The Arkfeld Ultra gives you those same three sources in an O-aluminium body with a glass lens. It makes sense if those materials matter more to you than a dedicated spot beam or USB-C. Olight ArkPro UK · Olight Arkfeld Pro UK · Olight Arkfeld Ultra UK
| What to compare | ArkPro | Arkfeld Pro | Arkfeld Ultra |
| White light | Dedicated flood and spot beams | One white beam | One white beam |
| Peak white output | 1,500 lm flood, 800 lm spot | 1,300 lm | 1,400 lm |
| Maximum rated beam distance | 205 m in spot mode | 102 m | 103 m |
| UV LED and green laser | 365 nm UV, Class 1 green laser | 365 nm UV, Class 1 green laser | 365 nm UV, Class 1 green laser |
| Body dimensions, length × width × depth | 124 × 27 × 16 mm | 120 × 27 × 16 mm | 120 × 27 × 16 mm |
| Weight with battery | 115 g | 111 g | 119 g |
| Built-in battery | 2,000 mAh | 1,500 mAh | 1,500 mAh |
| Charging | USB-C or Olight MCC magnetic cable | Olight MCC magnetic cable | Olight MCC magnetic cable |
| Moonlight at 1 lm | Up to 14 days | Up to 11 days | Up to 11 days |
| Water resistance | IPX7 | IPX7 | IPX7 |
ArkPro vs Arkfeld Pro vs Arkfeld Ultra at a glance
Figures are Olight’s specifications for the compared models and Class 1 variants. The claimed maximum beam distance describes a lab rating. How much detail you can see at that distance depends on the conditions and your target. ArkPro series Class 1 manual · Arkfeld Pro manual · Arkfeld Ultra manual
What changes when you carry a flat torch?
A torch can feel bulky against your leg even when it weighs very little. A flat body can lie with its broad face against the inside of a pocket, and its flat sides are less inclined to roll when you put it on a level bench. The three bodies are 16 mm deep on paper, so check the pocket opening, seams and amount of room beside your phone. The ArkPro is only 4 mm longer than either Arkfeld. The 8 g spread between the lightest and heaviest models is a smaller difference than whether the clip sits comfortably against the pocket seam. ArkPro series Class 1 manual · Arkfeld Pro manual · Arkfeld Ultra manual
The Arkfeld Pro and Ultra use a rotary selector for white light, UV or the green laser. On the ArkPro, the selector chooses the white flood, white spot or UV source, and a separate side button controls the green laser. If you often pull a torch out one-handed, check that you can feel the selector and reach the controls with your usual grip. Try the same motion in the gloves you wear outside. ArkPro series Class 1 manual · Arkfeld Pro manual · Arkfeld Ultra manual
When the beam matters more than the lumen figure
ArkPro for near and far in the same outing
On a walk home, the broad flood makes sense while you’re checking the pavement or sorting keys. If you need to pick out a gate latch across a dark yard, switch to the narrower spot, rated for 205 m at its peak. The spot has fewer lumens than the flood at maximum output but concentrates more of its light in a narrow beam. That distinction is the practical upgrade if you regularly swap between close and distant tasks. Olight ArkPro product specifications
Arkfeld Pro for routine white light with two extras
Choose the 111 g Arkfeld Pro if most of your white-light use is indoors, at the shed door or on a short walk. The white beam, UV and green laser cover the same categories as on the Arkfeld Ultra. Olight’s manual rates it for 9 hours 45 minutes at 100 lumens, a more useful comparison for repeated ordinary use than its initial 1,300-lumen Turbo output. Arkfeld Pro manual
Arkfeld Ultra for the body and lens upgrade
The Arkfeld Ultra has the same body dimensions, battery capacity and 100-lumen runtime as the Arkfeld Pro. Its O-aluminium body and glass lens are the reasons to choose it. The specifications add 100 lumens of peak output, with only 1 m more rated beam distance. If your current Arkfeld Pro already lights the jobs you do, those two figures offer little reason on their own to change. Olight Arkfeld Ultra UK · Arkfeld Ultra manual
Where UV and green pointing help
Checking a carpet or upholstery. In a dim room, 365 nm UV can help you spot areas that fluoresce. Cleaning residues and some fibres can fluoresce too. Use the glow to decide where to inspect under ordinary light. Keep the UV beam away from eyes. ArkPro series Class 1 manual · Olight Arkfeld UV and beam guide
Checking a Bank of England note. Use the Bank’s guide for the denomination in front of you. It recommends a good-quality UV lamp around 365 nm for the fluorescent feature and advises against LED detectors such as key fob types. Follow its issuer-specific guidance and check more than one security feature. Bank of England banknote FAQs · Bank of England advice for retailers and businesses
Pointing during an indoor presentation. The Class 1 green laser is useful for indicating a point on a fixed, matt chart. Use it on the intended surface, away from people’s eyes and reflective objects. If pointing is only an occasional task, decide between the three models based on the white beam and charging method. ArkPro series Class 1 manual · Arkfeld Pro manual · Arkfeld Ultra manual
Battery life and charging away from home
On the ArkPro’s flood setting, the rated Turbo starts at 1,500 lumens for four minutes, then drops to 520 lumens for a further 140 minutes. The Arkfeld Pro and Ultra also step down after their initial Turbo bursts. Compare the brightness you’ll actually use. The ArkPro’s headline 14 days and the Arkfelds’ 11 days are measured at one lumen, a setting better suited to finding items nearby in the dark. ArkPro series Class 1 manual · Arkfeld Pro manual · Arkfeld Ultra manual
If you usually top up at home, the magnetic lead is convenient to leave by the door. If you already pack a USB-C cable and power bank for a commute or weekend away, the ArkPro saves you from packing a separate torch lead. Both Arkfeld models need the Olight magnetic cable. ArkPro series Class 1 manual · Arkfeld Pro manual · Arkfeld Ultra manual
Frequently asked questions
Is the Arkfeld Ultra the same as the ArkPro Ultra?
They are different product names. Arkfeld Ultra is the three-source O-aluminium model in this guide. ArkPro Ultra is the four-source model in the ArkPro line, with its own separate flood and spot beams. Check the full name and laser class on the exact listing before ordering. Olight Arkfeld Ultra UK · Olight ArkPro Ultra
Should I upgrade my Arkfeld Pro?
Upgrade to the ArkPro if you frequently wish for a separate spot beam or USB-C charging. Choose the Arkfeld Ultra when its body and glass lens are the changes you want. When the Arkfeld Pro’s beam and magnetic charger already fit your routine, keep it.
Which flat EDC torch should you buy?
Buy the ArkPro for a mix of wide and focused lighting and easier USB-C top-ups. Choose the Arkfeld Pro for the lightest of these three torches and a straightforward three-source layout. Pick the Arkfeld Ultra if you prefer the O-aluminium body and glass lens and already charge at a fixed spot.
