Do you often encounter toys, mice, and game controllers that go out of work due to battery exhaustion while you are working or playing? Or your batteries seem to appear in all the wrong places, yet go missing when you need them most! Are you still frustrated trying to figure out which batteries are good or bad? Or Sick of waiting endlessly for them to charge?
The Game-Changer in Battery Charging
World's First 3-in-1 Battery Charger
Why settle for 3 devices, when you only need 1? Ostation X integrates a charger, a tester, and an organizer into one smart device, efficiently streamlining all your battery needs. Make battery management a pleasure, not a pain.
Drop, Charge & Go—Simplest Ever
With the unique automatic cascading process (analyzing - charging - sorting - storage), Ostation X makes charging as simple as using a vending machine—simply toss in batteries, let it handle the rest, and fetch them later. No fuss, no hassles. You’ve got more time to enjoy your life!
Perfect Organization for 32 Batteries
Ostation X automatically drops batteries into the storage/pickup compartment right after they’re fully charged, with a large storage capacity for 32 AA batteries. No wait, no clutter. You always have up to 32 fully charged ones organized and at the ready.
Unmatched Superchip Power
2X Charging Speed
Ostation X fully charges batteries in groups of four in a minimum of 2 hours—2X as fast as others in the market. Sleep through the night and wake up the next morning with multiple fully charged batteries ready to go!
Smart Automatic Detection
With an ingenious detection algorithm, Ostation X accurately analyzes battery sizes, types, polarity, and health, allowing only compatible, healthy batteries to be charged up regardless of (+)/(-) end orientation. Rest easy knowing that all the batteries will be properly treated.
Smart Automatic Sorting
Once the charging of a group of 4 batteries is complete, the compatible, healthy, and fully charged batteries go to the storage/pickup compartment, while the incompatible or bad ones are isolated into the invalid battery bin. No more mix-ups or guesswork!
Next-Level Home Battery Management
Intelligent App Control & Monitoring
Control your Ostation X and get real-time updates on every aspect through the Olight app.
8-Layer Protection System
Enjoy safe charging every time with eight layers of protection.
Specifications
Design Drafts & Product Optimization
Revolutionize your charging experience with Ostation X! This groundbreaking 3-in-1 powerhouse automatically analyzes, charges, and stores any brand's rechargeable AA batteries, making battery charging and use unprecedentedly simple and convenient.
| No | Question | Answer |
| 1 | When does the Ostation X stop charging batteries? |
The Ostation X will stop charging batteries under either of the following conditions: A: If any battery being charged reaches 1.46V, charging for that battery will stop. B: If any battery in a group of 1–4 batteries reaches the maximum charging time limit (2.5 hours in the fast charging mode or 3.8 hours in the standard charging mode), the device will stop charging the entire group. |
| 2 |
What’s the difference between the fast and standard charging modes? |
• Fast Charging Mode: Charges a group of 1–4 batteries in approx. 2.5 hours; this mode prioritizes speed. • Standard Charging Mode: Charges a group of 1–4 batteries in approx. 3.8 hours; due to the properties of Ni-MH batteries, this mode is more effective at extending their lifespan. |
| 3 |
Why does it take over an hour to fully charge my Ni-MH battery if I immediately recharge it with the Ostation X after a full charge? |
Ni-MH batteries naturally discharge slightly after reaching a full charge, causing their voltage to drop. When recharging fully charged Ni-MH batteries, the Ostation X uses a low current to safely bring them back to full charge, which is why the process takes extra time. Please update the software to version V2.0.0. This version has resolved this issue. The batteries will be fully charged within 10 minutes and dropped down to the storage compartment again. |
| 4 |
How do I pair my Ostation X with the Olight app?
To pair your Ostation X with the Olight app, begin by downloading the Olight app on your mobile phone. Enable cellular data, Bluetooth, and location services on your mobile phone. Open the app and tap "My Devices" to enter the device management interface. At this point, you can either log in to your account or choose to continue without logging in by tapping "No, continue without logging in."
Next, activate the pairing mode on your Ostation X. Ensure the device is powered on, then press the power button five consecutive times. This will cause the LED indicator ring to flash blue, signaling that the device is in the pairing mode. In the app, locate "Ostation X" in the left column and select it, followed by tapping the image of your device. Once the device is added, tap "Finish", and your Ostation X will appear in the device list.
If the device is not added successfully within 3 minutes, re-enter the pairing mode.
| 5 |
What triggers the auto sleep mode, and how do I exit it?
The device will automatically enter the auto sleep mode from one of the following causes.:
Cause A: No batteries were detected in the charging compartment after three attempts. Solutions: Method A: Press the power button once. Method B: Tap the "Start Charging" button in the Olight app. Method C: Activate vibration sensing by loading batteries or tapping the device. |
Make an “O” with your batteries in the comments below! Hope you enjoy yourselves in this event, can't wait to see your amazing photos!!
