In today's fast-paced world, unexpected power outages can be stressful and inconvenient. Being prepared for such emergencies is crucial, particularly when the outage occurs at night or in remote areas. With the right torch, you can navigate safely and efficiently in the dark.
Therefore, we have compiled a list of the top five Olight torches for dealing with power outages in 2025. These torches come with high brightness, long runtime, smart features, and user-friendliness, allowing you to feel secure and worry-free during a blackout.
1. Seeker 4 Pro — High-Lumen Rechargeable Torch for Power Outages and Large Spaces
Designed to turn dark rooms or outdoor areas into daylight.
Key Features:
● 4,600 lumens, beam distance of 260 meters
● Multi-functional holster with various carrying options, including wall mount and two charging modes
● Large side dial for stepless brightness adjustment, operable even with gloves
● Runtime of up to 15 days
💡 Why It's Useful for Power Outages:
Even during a full house blackout, the Seeker 4 Pro provides powerful area illumination. It can be wall-mounted for easy access. Whether you need to illuminate your living room or venture into a pitch-black garage, it's your go-to choice.
2. Baton 4 Premium — Pocket-Sized Torch and Power Bank
Light + Power, an all-in-one portable lighting and power solution.
Key Features:
● Maximum brightness of 1,300 lumens, beam distance of 170 meters
● Can be used for up to 190 days with protective casing
● 5,000mAh charging case can power the Baton 4 five times and charge mobile devices
● One-click shell control with a digital battery display
This is not just a torch; it combines emergency lighting and a portable backup power source. It can illuminate your home, charge your equipment, and be ready for any power outage situation.
3. Perun 3 — Headtorch for Power Outages and Everyday Use
High-performance headtorch with white and red light functions.
Key Features:
● High-quality LED outputs a strong 3,000 lumens white light in turbo mode. It also features soft red light with two brightness levels and a flashing mode for signalling.
● 5,000mAh battery supports a runtime of up to 20 days
● Comes with multiple mounting methods, including headband, magnetic base, clip, and hanging options
● Can be used as a right-angle torch with a large metal side button, making it easy to operate while wearing gloves
The Perun 3 headtorch not only offers a powerful light source and flexible usage options but also boasts long-lasting power, meeting various requirements during an outage to ensure your safety and convenience. The headband and magnetic base allow for hands-free use.
4. Oclip Pro — Compact and Lightweight Clip Light
With floodlight, spotlight, and red light functions.
Key Features:
● 500 lumens white floodlight, 120-meter spotlight, and 40/4 lumens red light
● Features clip, lanyard hole, and magnetic base for easy carrying in various ways
● USB-C charging interface
● Runtime of up to 144 hours
Whether clipped to a bag, clothing, or attached to a metal surface, it is conveniently portable, ready to face any power outage situation.
5. Marauder Mini — A Versatile Mini Monster: Floodlight, Spotlight, and RGB Light
When the sun sets, the Marauder Mini begins to shine. It’s suitable for various occasions—illuminating your room or lighting up the dark.
Key Features:
● Dual beam modes: floodlight for entire room coverage and spotlight for long distances
● Up to 7,000 lumens maximum output can light up large areas
● Custom 24Wh 32650 rechargeable lithium battery ensures extended runtime
● RGB auxiliary light provides visual signalling in emergencies
● Lockout mode and sensor protection ensure safe operation
Instantly switch between floodlight and spotlight—ideal for indoor blackouts or lighting up expansive outdoor areas like the garden. Whether staying at home during an outage or heading outside, the Marauder Mini ensures visibility and safety all night long.
Being prepared for power outages is not just about having a torch; it also involves selecting the right torch that suits your needs. Take some time to evaluate your torch options, such as the Oclip Pro clip light or Seeker 4 Pro, to ensure you are prepared for any situation. Don’t let the darkness hold you back; get ready today!
