TL;DR: The next-generation Olight Perun X and Perun Ultra redefines hands-free lighting. Featuring an industry-first single glass optical lens combining spotlight, pure floodlight, and night-vision red light, this high-performance head torch delivers up to 2,400 lumens. Functions seamlessly as a right-angle flashlight or tactical torch light, outperforming standard flashlight and UV torch setups with a 4,000mAh battery, IPX7 waterproofing, and DialFit adjustment for extreme outdoor adventures.
As dark autumn evenings and chilly winter nights roll into the UK, having dependable, high-powered illumination is essential for evening dog walks, home property maintenance, and night trail runs. Standard handheld lights force you to compromise between hand dexterity and optical range when navigating damp, uneven terrain after dark. Olight is proud to introduce the Perun X and Perun Ultra—a powerful next-generation head torch engineered to tackle demanding British weather with ease under the slogan: "Head to hand. Always in focus."
- Industry-First Glass Optical Lens for Multi-Beam Versatility
- Convert From Head Torch to Right-Angle Flashlight in Seconds
- Intuitive Rotary Selector & Micro-Laser Status Displays
- DialFit Precision Headband for High-Intensity Activity
- All-Weather Durability: Premium Alloys, Thermal Protection & IPX7 Waterproofing
- Long-Lasting 4,000mAh Power Platform & Dual Charging
- Technical Specifications Comparison
The Perun X and Ultra incorporate an innovative single glass lens optical system that houses spotlight, pure floodlight, and red light capabilities. Delivering up to 2,400 lumens (30,625 cd) on the Ultra and 2,000 lumens (22,500 cd) on the X in combined Spot + Flood mode, rigorously calibrated according to ANSI/PLATO FL 1 Performance Standards for true optical accuracy, this torch light allows you to seamlessly switch from broad area floodlighting (up to 1,000 lm) to long-distance beam performance reaching up to 350 meters on Ultra and 300 meters on X. Furthermore, a dedicated 60-lumen red light mode (including low, moonlight, and SOS settings) preserves your natural dark adaptation during night walks or emergency situations.
Versatility is key when working in dark or cramped spaces. Thanks to a quick-release mounting bracket, engineered to eliminate the frustration of awkward detachment mechanisms during cold-weather outdoor tasks, the light detaches quickly from the headband to function as a compact right-angle flashlight. Use the stainless steel clip to secure it to your coat, belt, or backpack, or use the strong magnetic tailcap to attach the torch directly to metallic surfaces like vehicle bonnets or steel racking for hands-free maintenance work.
Olight Perun X
Reliable 2,000-lumen head torch featuring an integrated single glass lens (Spot/Flood/Red), AL6061-T6 aluminum body, quick-release bracket, and dual USB-C/MCC charging.
Shop Perun X →Intuitive Rotary Selector & Micro-Laser Status Displays
Switching light modes during nighttime activities should be fast and foolproof. Both models feature an ergonomic rotary selector wheel surrounding a central power and brightness button. Twist to instantly choose between spotlight, floodlight, or red light, and press to adjust brightness levels. The Perun X includes a clear battery level indicator, while the flagship Perun Ultra steps up technology with a micro-perforated, laser-etched display showing both battery level and active brightness intensity directly through its metal body.
Designed for extended wear during damp UK nights, the wide 35mm breathable headband includes high-visibility reflective safety strips to keep you seen from 360 degrees. While the Perun X offers a standard headband buckle, the Perun Ultra introduces a bidirectional DialFit system. This mechanism allows precise, one-handed micro-tightening and loosening even when wearing thick winter gloves—delivering a custom, pressure-free fit that eliminates slippage during trail runs or heavy maintenance work.
Engineered to handle harsh British rain and mud, the Perun X features an AL6061-T6 aluminum body (available in Black and Orange), while the Ultra is built from ultra-hard, scratch-resistant OAL alloy (Olive Green). Both carry an IPX7 waterproof rating (verifying protection against water immersion up to 1 meter for 30 minutes, certified under IEC Standard 60529) alongside 1.5-meter drop resistance. For added safety, built-in smart thermal control works alongside an infrared optical proximity sensor, which automatically drops brightness when an object blocks the lens within one second of entering High or Turbo modes to prevent overheating or scorching.
Olight Perun Ultra
Flagship 2,400-lumen lighting system with ultra-hard OAL alloy housing, bidirectional DialFit adjustment headband, laser-etched status display, and 350-metre throw.
Shop Perun Ultra →Long-Lasting 4,000mAh Power Platform & Dual Charging Options
Both models are powered by a high-capacity 4,000mAh 18650 battery platform that delivers up to 33 days of continuous runtime in 1-lumen Moonlight mode. To make power top-ups convenient wherever you are, both models feature a rubber-sealed USB-C charging port for direct plug-in charging, while maintaining full compatibility with optional Olight MCC3 magnetic charging cables.
| Feature / Specification | Perun X | Perun Ultra |
| Max Output (Spot + Flood) | 2,000 Lumens | 2,400 Lumens |
| Max Beam Distance | 300 Metres (22,500 cd) | 350 Metres (30,625 cd) |
| Body Material | AL6061-T6 Aluminum Alloy | High-Strength OAL Alloy |
| Net Weight | 120 g / 4.23 oz | 130 g / 4.59 oz |
| Headband Adjustment | Standard Adjustment Buckle | Bidirectional DialFit System |
| Status Display | Battery Level Indicator | Laser-Etched Battery & Brightness Indicators |
| Available Colors | Black, Orange | Olive Green |
| Waterproof & Drop Rating | IPX7 Waterproof, 1.5m Drop Resistance | IPX7 Waterproof, 1.5m Drop Resistance |
How waterproof is the Olight Perun X / Ultra for rainy UK outdoor use?
Both models carry an IPX7 waterproof rating, meaning they can withstand heavy rain and accidental water immersion up to 1 meter deep for 30 minutes, giving complete operational confidence during torrential UK downpours.
Does this torch feature specialized beam selectors?
Yes. It features an intuitive rotary selector dial allowing you to switch instantly between spot, flood, and red light modes, alongside push-button brightness controls for effortless tactile operation under pressure.
Is the headband washable after outdoor activities?
Yes, the 35mm breathable headband can be detached easily from the quick-release bracket for cleaning after muddy hikes, maintaining long-term hygiene and comfort.
Whether you require a heavy-duty flashlight for professional maintenance work or a reliable head torch for night walks, the Olight Perun X and Ultra deliver unmatched brightness, range, and comfort. Don't let dark weather freeze your outdoor routines—invest in dependable gear built to withstand the elements. Upgrade your winter lighting setup today!
