TL;DR: Upgrade your winter everyday carry with the new Olight Oclip 2 Pro in Nebula Violet and Mech Green. Delivering up to 530 lumens, this versatile torch functions as a hands-free head torch alternative or compact flashlight. Featuring a 360° swivel clip, 115° tilting head, multi-source flood, spot, red, and UV torch capabilities (Ultra edition), and an optional 1,000 mAh charging dock, it provides ultimate hands-free torch light performance for dark UK nights.
As autumn settles into winter across the UK, shorter days mean longer nights—with the UK Met Office recording as few as 7 to 8 hours of daylight during midwinter. Whether you are commuting after dusk, walking the dog through damp countryside tracks, or tackling DIY maintenance tasks in an unlit garage, having a compact, reliable torch light ready at a moment’s notice is essential. According to safety guidance from the Royal Society for the Prevention of Accidents (RoSPA), carrying high-visibility personal illumination significantly reduces night-time accidents during winter months. To bring both high-performance illumination and bold style to your everyday kit, Olight is thrilled to launch two striking new colorways for its acclaimed multi-source clip light: the Oclip 2 Pro in Nebula Violet and Mech Green, engineered to match the iconic colorways of the Olight ArkPro Series in Nebula Violet and Mech Green—crafted with the exact same dynamic anodic oxidation finishes that resist wear and look distinctly futuristic in your hand.
- 1. Complete Directional Control: 115° Tilting Head and 360° Swivel Clip
- 2. Three Versatile Light Modes: Up to 530 Lumens Output
- 3. Hands-Free Mounting Options: Clip, Stick, or Hang
- 4. Perfect EDC Pairing: Matching ArkPro Colors in Mech Green & Nebula Violet
- 5. Extended Runtime with On-the-Go Mobile Charging Dock
- 6. Weather-Ready Durability: IP66 Water Resistance & 2m Drop Rating
- 7. Frequently Asked Questions (FAQ)
- 8. Elevate Your Everyday Carry Today
Olight Oclip 2 Pro
Featuring 530-lumen output, a 115° tilting head, 360° swivel clip, and dual-mode charging dock. Available in Nebula Violet & Mech Green.
Shop Oclip 2 Pro →Complete Directional Control: 115° Tilting Head and 360° Swivel Clip
Working in tight engine compartments, under dark sink plumbing, or inside pitch-black utility spaces often means holding a standard handheld flashlight with your teeth or struggling to angle it correctly. The Oclip 2 Pro solves this frustration with an innovative dual-axis directional system, allowing you to tilt the light head through 115° and rotate the mounting clip a full 360°. This ergonomic design guarantees exact light placement, so your hands remain 100% free to focus on the job at hand.
Engineered to withstand demanding everyday use, both the dual-axis mechanism and the heavy-duty clip have undergone rigorous 10,000-cycle rotation and clipping tests. You can easily adjust the beam angle precisely where you need it without altering your posture or repositioning the main body, making it a seamless hands-free companion that effortlessly adapts to your posture whether clipped to a pocket or a cap—echoing the precision engineering found in Olight’s flagship ArkPro flat EDC lineup.
Different tasks demand tailored lighting setups. Designed with tactile knurling for easy grip even with winter gloves on, the intuitive rotary selector dial and center button let you instantly switch between three specialized light modes: tested in strict compliance with ANSI/NEMA FL1 Standards for output precision.
- Pure Floodlight: Delivers up to 530 lumens of wide, even illumination to cover an entire work area or illuminate dark walking paths.
- Focused Spotlight: Projects a focused beam reaching up to 125 metres, ideal for spotting distant landmarks or navigating unlit streets.
- Red Light: Preserves your natural night vision and serves as an eye-catching warning signal during night walks or roadside emergencies.
Whether you need a versatile torch light for vehicle maintenance or dependable outdoor lighting while trekking, the Oclip 2 Pro delivers complete hands-free convenience. The robust spring clip opens wide to securely grip straps, jacket lapels, or coat collars up to 14 mm thick, transforming your gear into an instant wearable light source without feeling top-heavy.
Integrated high-strength magnets on the MCC tail and the clip surface snap effortlessly onto steel surfaces like toolboxes, steel racking, or car bonnets, providing rock-solid magnetic adhesion so you can work distraction-free under any metal hood. Alternatively, use the top attachment point to hang the light overhead from hooks or tent loops.
For UK EDC enthusiasts who value both striking visual style and maximum lighting versatility, the new Mech Green and Nebula Violet finishes create a seamless, color-coordinated setup between your primary pocket flashlight and hands-free clip light:
- Mech Green Synergy: Pair the high-output power of the ArkPro in Mech Green in your pocket with the matching Oclip 2 Pro in Mech Green clipped to your winter coat or bag strap. The bold, industrial aesthetic of the Mech Green anodized finish delivers a rugged, technical look built for dark winter commutes and trade work.
- Nebula Violet Elevation: Combine the sleek ArkPro in Nebula Violet with the matching Oclip 2 Pro in Nebula Violet for a refined, futuristic aesthetic. The deep metallic purple finish adds distinct character to evening countryside walks and everyday carry kits without sacrificing scratch resistance.
By using the ArkPro as your multi-functional primary torch (combining 1,500lm flood, spotlight, 365nm UV beam, and green laser) alongside the flexible hands-free mounting of the Oclip 2 Pro, you gain complete, multi-angle lighting coverage in a unified color palette.
Olight ArkPro Series (Matching Colors)
Complete your EDC setup with the matching ArkPro in Nebula Violet or Mech Green. Combines 1,500lm flood light, spotlight, 365nm UV beam, and green laser with 7 lighting configurations and 2,000mAh dual charging.
Shop ArkPro Colors →Extended Runtime with On-the-Go Mobile Charging Dock
Long outdoor excursions and extended work shifts require reliable power management. The Oclip 2 Pro offers versatile dual-charging capability via USB-C or magnetic charging cable (MCC), eliminating battery anxiety during outdoor adventures or midnight callouts.
For users requiring maximum endurance, the Oclip 2 Pro Premium edition comes bundled with a 1,000 mAh Mobile Charging Dock. This pocketable dock automatically tops up your torch while stored, effectively doubling your total operating runtime while providing clear battery indicator displays for both units at a glance, ensuring your light is fully charged and ready whenever you reach into your pocket.
Built using premium AL6061-T6 aluminum alloy, the Oclip 2 Pro is engineered to take on tough UK weather conditions. Weighing only 75.5 grams for the light itself, it fits seamlessly into coat pockets or pouch organizers without added bulk.
With certified IP66 water resistance under IEC 60529 standards against heavy rain and mud, combined with a 2-metre drop resistance rating, this torch light is built to perform reliably season after season, giving you total confidence whether caught in a sudden downpour or dropping it on hard tarmac.
What is the primary difference between the Oclip 2 Pro and Oclip 2 Ultra?
The Oclip 2 Pro features floodlight, spotlight, and red light sources. The Oclip 2 Ultra builds upon these features by incorporating a combined Red and UV light emitter, ideal for quick inspections, forensic checking, bank note validation, and UV torch detection applications.
Are Nebula Violet and Mech Green available in the Premium dock bundle?
Yes, both Nebula Violet and Mech Green are available as stand-alone Oclip 2 Pro units and as Oclip 2 Pro Premium bundles featuring the 1,000 mAh Mobile Charging Dock, giving you the option to choose between lightweight everyday carry or maximum power endurance.
How do I attach the torch if no metallic surface is available?
You can use the 360° rotating clip to fasten the torch onto jacket edges, pockets, or straps up to 14 mm thick, or hang it overhead via the built-in hanging point or loop it onto your backpack straps for continuous forward illumination.
Blending striking aesthetics with ultra-rugged practical design, the new Nebula Violet and Mech Green Oclip 2 Pro models are your ultimate illumination companions for trade work, evening walks, and everyday tasks. Don't let short winter days slow you down—explore the new collection today and experience true hands-free lighting freedom!
