The Ultimate Olight Baton Series Buyer’s Guide (2026 Updated Edition)
If you’ve spent any time in the EDC (Everyday Carry) community, you know that the Olight Baton series is a true industry benchmark. It remains the gold standard for compact, reliable, and powerful illumination. However, as we head into 2026, the lineup has expanded significantly. Choosing between the classic Baton 4, the specialised Turbo, and the high-performance Baton 4 Pro and Baton Ultra has become a strategic decision for enthusiasts.
Are you looking for the longest battery life, the furthest beam throw, or the most compact power-to-size ratio? This Olight Baton series guide is designed to cut through the specifications and help you decide exactly which Olight Baton to buy based on your specific lifestyle and professional needs.
Best All-Rounder: Olight Baton 4
For most users, the Baton 4 Premium Edition remains the “Goldilocks” of the series. It strikes the perfect balance between pocketable size, 1,300-lumen brightness, and modern convenience.
Olight Baton 4 Premium Edition
- Output: 1,300 Lumens
- Runtime: Up to 190 days (with case)
- Feature: Wireless Charging Case
The standout feature of the Baton 4 is its Premium Edition charging case. Not only does it protect the light, but it also acts as a portable power bank, extending the runtime to a staggering 190 days in moonlight mode. It’s the ultimate “set it and forget it” torch for travellers and daily commuters.
Why choose the Baton 4?
- Portability: It’s small enough to disappear in your pocket or clip onto a hat brim for hands-free use.
- Intuitive UI: Micro-laser perforated indicators provide instant feedback on battery levels and brightness settings.
- The Case: Ideal for users who dislike hunting for charging cables; the wireless case is a game-changer for EDC organisation.
Best for Distance: Olight Baton Turbo
Sometimes, a wide flood beam isn’t enough. If you need to identify objects at the far end of a field or navigate large outdoor spaces, you need the Baton Turbo Long-range Pocket EDC Torch.
Olight Baton Turbo
- Beam Distance: 510 Metres
- Output: 1,000 Lumens
- Focus: Extreme Long-Range Throw
Why choose the Baton Turbo?
- Extreme Reach: Offers a beam distance that typically requires a much larger flashlight.
- Security and Search: Ideal for rural homeowners or dog walkers in expansive parks.
- Precision Engineering: Features a specialised LED and reflector that punches a tight beam deep into the darkness.
Best for Professional Versatility: Olight Baton 4 Pro
For mechanics, engineers, and outdoor professionals, the Baton 4 Pro is the ultimate upgrade. It bridges the gap between a standard EDC light and a full-sized professional tool.
Olight Baton 4 Pro
- Brightness: 1,600 Lumens
- Durability: IPX8 Waterproof
- Control: Dual Switch Functionality
The “Pro” designation reflects its 1,600-lumen output and rugged build. Crucially, it features an improved thermal control system that keeps the surface temperature below 45°C, ensuring safe handling even during prolonged use at high settings. With its IPX8 waterproof rating, it can withstand complete submersion, making it reliable in any British weather condition.
Why choose the Baton 4 Pro?
- Dual Charging: Flexibility via Olight’s Magnetic Charging Cable (MCC) or the hidden USB-C port.
- Optimised Safety: Advanced thermal management keeps the torch comfortable to hold at all times.
- Extended Runtime: Powered by a 3,500 mAh battery, it offers up to 100 days of runtime in moonlight mode.
Best for Peak Performance & Tech: Olight Baton Ultra
If you demand the pinnacle of lighting technology, the Baton Ultra is the current flagship of the series, pushing the boundaries of compact EDC performance.
Olight Baton Ultra
- Max Output: 1,800 Lumens
- Max Throw: 300 Metres
- Tech: Self-developed EIP 1 LED
The Baton Ultra represents the cutting edge of Olight’s R&D. It features the self-developed EIP 1 LED, which delivers an exceptionally crystal-clear, natural white beam with a ultra-low Duv of <0.006 across all modes. Constructed from OAL™ (O-aluminum), its body offers superior scratch resistance and durability over standard aluminium alloys. With a massive 1,800 lumens and a 300-metre reach, it is the definitive choice for those who refuse to compromise.
Why choose the Baton Ultra?
- Cutting-Edge Beam Quality: The EIP 1 LED produces a crystal-clear, natural white beam with superior colour rendering and ultra-low Duv.
- Unmatched Durability: The OAL™ (O-aluminum) body offers incredible scratch resistance and a premium tactile feel.
- Peak Specs: 2-metre drop resistance and 300-metre throw make it the most capable Baton ever made.
Quick Spec Comparison Chart
Compare the technical specifications of these four titans side-by-side to find your ideal match.
| Feature | Baton 4 | Baton Turbo | Baton 4 Pro | Baton Ultra |
| Max Lumens | 1,300 lm | 1,000 lm | 1,600 lm | 1,800 lm |
| Max Throw | 170 m | 510 m | 200 m | 300 m |
| Drop Resistance | 1.5 m | 1.5 m | 1.5 m | 2.0 m |
| Charging | Wireless Case / MCC | MCC | Dual (MCC + USB-C) | Dual (MCC + USB-C) |
Conclusion: Find Your Perfect Torch
The “best” torch is the one you actually have on you when the lights go out.
- Choose the Baton 4 Premium for ultimate pocketability.
- Choose the Baton Turbo for long-distance spotting and outdoor security.
- Choose the Baton 4 Pro for a professional work tool with advanced heat control.
- Choose the Baton Ultra for maximum lumens and the latest EIP 1 technology.
Ready to pick your partner in the dark? Shop the full Olight Baton Series now and find the perfect beam for your next adventure.
Frequently Asked Questions
Which Olight Baton is best for daily carry?
The Baton 4 is widely considered the best for daily carry due to its ultra-compact size and wireless charging case.
Is the Olight Baton 4 Pro waterproof?
Yes, the Baton 4 Pro features an IPX8 waterproof rating, meaning it can be submerged in water up to 2 metres deep.
What is the main difference between the Baton Turbo and the Baton Ultra?
The Baton Turbo is a specialised “thrower” for distance (510 m), while the Baton Ultra is a flagship offering higher output (1,800 lm) and a body constructed from OAL™ (O-aluminum) for superior durability and scratch resistance.
