Whether you’re an everyday-carry minimalist, a hands-on professional, or a gear enthusiast who demands the absolute best, there is a Baton built exactly for you. In this comprehensive guide, we break down every meaningful difference between the Baton 4, Baton 4 Pro, and Baton Ultra — spec by spec, feature by feature — so you can choose your perfect illumination tool with total confidence.
⚡ At a Glance: Key Differences in 30 Seconds
Before we dive in, here’s the quick-reference table. Scan the entries below to see where each model excels and identify the best value for your specific needs.
| Specification | Baton 4 | Baton 4 Pro | Baton Ultra |
| Max Output | 1,300 lumens | 1,600 lumens | 1,800 lumens BEST |
| Max Beam Distance | 170 m | 200 m | 300 m BEST |
| Light Intensity | 7,225 cd | 10,000 cd | 22,500 cd BEST |
| LED Tech | Standard High-Perf | Standard LED (15 W) | EIP 1 (18 W) EXCLUSIVE |
| Switches | Side switch only | Side + Tail (Dual) | Side + Tail (Dual) |
| Body Material | 6061 Aluminium | 6061 Aluminium | O-Aluminium (OAL) NEW |
🔦 The Baton 4: The Benchmark for Compact EDC
If the term “EDC” had a flagship example, the Baton 4 would be it. Shorter than your index finger and lighter than a set of car keys, it packs a serious 1,300-lumen punch. It’s the ultimate proof that you don’t need bulk to achieve professional-grade brightness.
Whilst the torch itself uses a compact IMR16340 battery, the real magic lies in the Premium Edition charging case. With a 5,000 mAh reservoir, it can recharge the Baton 4 up to five times, extending your runtime to a remarkable 190 days in moonlight mode.
BEST FOR The Minimalist
- Precious Pocket Space: You want the smallest footprint without sacrificing intensity.
- Urban EDC: Perfect for dog walks, checking under the bonnet, or navigating dark car parks.
- Travellers: The wireless charging case makes it the ultimate companion for off-grid trips.
⚙️ The Baton 4 Pro: The Professional Workhorse
The Baton 4 Pro is Olight’s answer to users who demand more — more runtime, more control, and more durability. Equipped with a robust 3,500 mAh 18650 battery, it delivers a consistent 1,600 lumens for those who rely on their tools all day.
The Dual-Switch Advantage
The defining feature of the Pro model is the tactical tail switch. Whilst the side switch handles daily mode cycling, the textured tail switch provides instant, high-pressure access to Turbo. It’s the ideal blend of “side switch for finesse, tail switch for speed.”
🏆 The Baton Ultra: Pocket Performance Redefined
The Baton Ultra isn’t simply an upgrade; it’s a showcase of Olight’s latest innovations. Packing 1,800 lumens and a remarkable 300-metre reach, it delivers searchlight-level performance in a body nearly identical in size to the Baton 4 Pro.
Proprietary Technology Deep-Dive
🔬 EIP 1 — The Future of LEDs
The Efficient Intense Pure (EIP) LED is Olight’s self-developed masterpiece. It offers 10% higher efficiency and a pure natural-white beam that eliminates the “green/yellow tint” found in mass-market emitters.
🔩 O-Aluminium (OAL) Super-Alloy
Constructed from OAL, the Ultra’s body is 1.73× harder than standard 6061 aluminium. This isn’t merely for show; it survives 2-metre drops onto concrete and resists scratches with a tenacity approaching that of titanium.
BEST FOR The Enthusiast
- The “Long Reach” EDC: You want 300 metres of throw in your pocket.
- Beam Quality Purists: You demand pure, tint-free light with a flawless hotspot.
- Extreme Environments: You need the scratch-resistant OAL body for heavy-duty use.
🏁 Final Verdict: Your Perfect Match?
If pocket space is your number-one priority, this is the finest compact EDC torch Olight has ever produced.
The “sweet spot.” Dual switches and outstanding battery life make it a reliable daily companion for most users.
Uncompromising performance. If you want the very best beam, throw, and build quality, this is it.
❓ Frequently Asked Questions
What is the biggest difference between the Baton 4 and the Baton 4 Pro?
It comes down to utility and size. The Baton 4 is designed for ultra-portable, intermittent use with a side switch. The Baton 4 Pro is a full-sized tool with triple the battery capacity and a tactical tail switch for professional duty.
Is the Baton Ultra worth the extra investment over the Pro?
If you need distance and beam purity, absolutely. The Ultra throws 100 m further and features the OAL super-alloy body, which is significantly more resistant to hard use and drops than standard aluminium.
