Night lights have come a long way from being basic, single-coloured bulbs to now being innovative, multifunctional lighting solutions that offer convenience, versatility, and style. Olight, a leading brand in the lighting industry, offers a range of night lights with advanced features and designs to meet different needs and preferences. In this blog, we will explore the differences and connections between two popular night lights from Olight - the Obulb Plus and the Obulb Pro S.
Obulb Plus
The Obulb Plus is a multicolour, rechargeable, and magnetic light orb that measures 3.15 inches in diameter, making it larger than the Obulb Pro S. The Obulb Plus is designed to provide illumination, ambient light, and decoration with its maximum output of 300 lumens and a runtime of up to 49 hours.
What sets the Obulb Plus apart is its touch switch on the top feature, which offers 7 manual modes and step-less dimming by pressing and holding the switch.
The Obulb Plus also features an app control feature, which allows users to control the light using Olight's new App, Olight Hub. With the app, users can turn the light on/off, change brightness levels and modes, adjust the light colour using the colour wheel, and check the remaining battery level. Group controlling is also possible, allowing users to control multiple Obulb Plus lights simultaneously with a simple tap.
The Obulb Plus has a magnetic bottom that can be used to attach the light to any smooth surface when paired with the adhesive metal badge. It is also durable with its 1-meter impact resistance and IPX7 waterproof rating.
Features
The Obulb Plus boasts several features that make it a convenient and versatile night light option. These features include:
● New App Controlled
The Obulb Plus can be controlled by the Olight Hub app via Bluetooth, allowing users to easily change modes, brightness, and colour, and check the remaining power. The app also offers additional functions such as group control, music rhythm, whack-a-mole game, countdown, and more.
● Larger Size
With a diameter of 3.15 inches, the Obulb Plus is larger than the Obulb Pro S, providing a wider illumination area and a more substantial feel in the hand.
● Stepless Dimming Touch Switch
The touch switch on the top of the Obulb Plus allows users to manually control the light, including turning it on/off, changing modes and brightness levels. The stepless dimming feature allows users to adjust the brightness to their desired level by pressing and holding the switch.
● Magnetic Bottom
The Obulb Plus features a magnetic bottom that can be attached to almost any smooth surface when combined with the adhesive metal badge, providing versatile placement options around the house.
● Long Runtime
The built-in 2000mAh battery of the Obulb Plus allows for a runtime of up to 49 hours, reducing the need for frequent charging.
● One Step Charging
The Obulb Plus can be easily charged with the magnetic charging cable, allowing for quick and convenient charging in just 3 hours.
● Sturdy Build
The Obulb Plus is designed to withstand tough conditions with its IPX7 waterproof rating and 1-meter impact resistance, making it durable for various environments and adventures.
Obulb Pro S
The Obulb Pro S is the updated version of the Obulb Pro, featuring more colourful modes and additional functionalities. It has the same size as the Obulb Pro, with a diameter of 2.56 inches, making it compact and portable. It delivers a maximum output of 240 lumens and has a runtime of up to 6.5 days, providing reliable lighting for extended periods.
FEATURES
● Stepless Dimming Bottom Switch: Easily control the brightness level of the Obulb Pro S by pressing and holding the bottom switch, allowing for a more customizable lighting experience.
● New App Controlled: The Obulb Pro S can be controlled by the Olight Hub via Bluetooth. With the APP, users can change its mode, brightness, and colour, and check the remaining power. Group control, music rhythm, countdown, and other functions are also available.
● Compact Size: With a 2.56-inch diameter, the Obulb Pro S is smaller than the Obulb Plus, making it more portable and convenient for on-the-go use.
● Long Runtime: The built-in 1650mAh battery allows for up to 6.5 days of continuous lighting, providing extended illumination without frequent charging.
● One Step Charging: The Obulb Pro S can be fully charged in just 3 hours with its magnetic charging cable, making it quick and easy to replenish the battery.
● Versatile Attachment: The magnetic bottom of the Obulb Pro S allows it to be attached to any smooth surface when paired with the adhesive metal badge, offering flexibility in placement.
● Rugged Build: With an impact resistance of 1.5 meters and an IPX7 waterproof rating, the Obulb Pro S is designed to withstand tough conditions and provide reliable performance in various environments.
Comparison and Connection
1. The differences between Obulb Plus and Obulb Pro S
The most important thing is their difference:
● Size
One of the main differences between Obulb Plus and Obulb Pro S is their size. The Obulb Plus is larger, with a diameter of 3.15 inches, while the Obulb Pro S has a diameter of 2.56 inches.
The larger size of the Obulb Plus provides a wider illumination area, making it suitable for ambient lighting or decoration, while the smaller size of the Obulb Pro S makes it more portable and convenient for on-the-go use.
● Lumen output
The Obulb Plus has a maximum output of 300 lumens, while the Obulb Pro S has a maximum output of 240 lumens.
The Obulb Plus is slightly brighter, providing more illumination in larger spaces, while the Obulb Pro S is still bright enough for most everyday use.
● Runtime
The Obulb Plus has a longer runtime of up to 100 hours on the lowest brightness setting, while the Obulb Pro S has a runtime of up to 6.5 days on the lowest brightness setting.
The Obulb Plus has a longer battery life, making it suitable for extended use without frequent recharging, while the Obulb Pro S still provides ample runtime for everyday use.
● The optional modes on the APP are different
Obulb Plus --- A total of 21 colour light modes are available.
Obulb Pro S --- A total of 12 colour light modes are optional.
● The operation mode is different:
Obulb Plus --- Olight adopts a touch switch for the first time, the switch position is on the top, and it can be easily controlled by lightly touching and patting the top of the bulb, and the operating experience is different;
Obulb Pro S --- button switch, the switch position is at the bottom, maintaining the operation method of the old Obulb Series;
● The special effects of the ambient light mode are different:
Obulb Plus --- 75 full-colour lamp beads are used, and the three-dimensional layout of the lamp beads makes the colored light more delicate and richer in colour. Brand-new ambient lighting effects, comfortable lighting effects: such as flame mode, fireworks mode, etc., and there is a large space for subsequent expandable lighting modes, which can be continuously upgraded remotely to enrich the lighting effects.
Obulb Pro S --- Only 8 colourful lamp beads, limited lighting effects, and small expandable space for lighting modes.
● The supporting magnets are different:
Obulb Plus --- Using a new magnetic attraction piece, the magnetic force is stronger and the adsorption is firmer.
Obulb Pro S --- Use the old magnet.
2. The similarities between Obulb Plus and Obulb Pro S
Despite their differences, the Obulb Plus and Obulb Pro S share several similarities that make them stand out as high-quality night lights from Olight.
● App control features
Both the Obulb Plus and Obulb Pro S can be controlled through the Olight Hub app, allowing users to easily adjust their modes, brightness levels, and colours. The app also offers additional functions such as group control, music rhythm, and countdown, providing enhanced convenience and customization options.
● Charging time
Both Obulb Plus and Obulb Pro S can be fully charged in 3 hours.
● Magnetic bottom
Both the Obulb Plus and Obulb Pro S feature a magnetic bottom that allows them to be attached to almost any smooth surface when paired with the adhesive metal badge. This magnetic attachment feature makes them versatile in placement and convenient to use in various scenarios.
● Durability
Both the Obulb Plus and Obulb Pro S are built to be durable and reliable. They both have IPX7 waterproof ratings, impact resistance are 1m and 1.5m that make them suitable for outdoor adventures and tough environments.
The Obulb Plus and Obulb Pro S are two innovative night lights from Olight that offer convenient and versatile lighting solutions. They are both feature-rich, with app control, magnetic attachment, and durable build, making them suitable for various scenarios. The Obulb Plus is larger, brighter, with more color light modes, and more smart operation, while the Obulb Pro S is smaller, and more portable. Users can choose between them based on their specific needs and preferences, whether it's for ambient lighting, decoration, or on-the-go use. With their advanced features and reliable performance, the Obulb Plus and Obulb Pro S are excellent options for those in need of a high-quality night light.
