Obulb Pro S Smart Light (With MCC1A Charging Cable)
● New App Controlled: When it is connected to a smartphone via Bluetooth, you can easily change its mode, brightness and color. You can also check the remaining power through the Olight Hub app, along with more interesting functions are also available, such as group control, music, rhythm, countdown, etc.
● Stepless Dimming: Allows you to reach any brightness level between 1% and 100% just by pressing and holding the bottom switch.
● Fast Charging & Magnetic Base: With Olight’s signature magnetic charging, it can be fully charged in 3 hours. The included adhesive metal badge allows easy mounting to almost any smooth surface.
● Long Runtime: The built-in 1650mAh battery allows up to 6.5 days of use, which satisfies the requirement of almost one week of lighting.
● Sturdy & Durable: IPX7 waterproof and 1.5-meter impact-resistant, the Obulb Pro S is ready for any environment and adventure.
* Download the Olight APP through the App Store (IOS users) or Google Play (Android users).
Note: If not in use, it is recommended to enable the "Auto Sleep" function. When it is not turned on or in sleep mode, it needs to maintain a real-time Bluetooth connection with the APP, so the static power consumption is relatively large.
