Marauder Mini High Power Torch With RGB
● Smaller in Size, Yet Incredibly Powerful: Marauder Mini, the miniature version of Olight's Marauder, has a 7,000-lumen max output and a 43.5-hour max runtime, thanks to its custom 24Wh 32650 rechargeable lithium battery.
● Dual-beam with Spot and Flood: An array of LEDs offers two powerful beam choices: a 600-meter max throw from the central LED’s spotlight beam or a 7,000-lumen max output floodlight beam from the 9 surrounding LEDs.
● Uniformly Distributed RGB Colour LEDs: Three RGB LEDs are uniformly distributed around the lens, greatly increasing its usefulness on any outdoor adventure.
● Easy toggle switch & 3D rotary knob switch operation: The toggle switch in the middle of the body allows quick access to select either spotlight or floodlight, while the upper rotary knob is intuitive to adjust brightness levels.
● Safest in its class: A built-in thermal sensor and cooling fins to ensure safety in case of overheating and lens obstruction
