Have you ever had this problem: every time you go on a trip or work, you have to choose and carry a suitable torch, which is very inconvenient and painful?
For example, if you're going on a night camping trip, you'll need a powerful torch to illuminate the tent or distant targets; if you're staying in a hotel, you might need a UV light torch to inspect the cleanliness of the room. Laser torchs are also useful for pointing out objects while hunting or on field trips.
In this case, we must always buy and carry a variety of torches, which not only adds to the financial burden but also increases the difficulty of storage and carrying, making people feel extremely inconvenient.
In addition to that, if the torch
Unable to face sudden harsh environment
With use, the power is quickly exhausted
It cannot be used normally after being accidentally dropped.
A torch that is carried around but does not function properly when needed is not a truly effective one.
If you're looking for a more convenient and practical solution, then keep reading! I will introduce you to Olight’s popular torch Arkfeld Pro, which can meet your needs in different scenarios and make your travels and adventures more enjoyable and convenient.
Remember to leave a comment after reaching the bottom--I don’t want you to miss a chance to win a prize!
Olight's FIRST rechargeable torch with 3 light sources - Arkfeld Pro
Let’s take a look at the Arkfeld Pro packaging first.
Key information such as brightness lumens and usage are clearly marked on the box, allowing you to understand the product performance at a glance. And in the included bag, you'll find Olight's unique magnetic charger, which is a very practical accessory. It's worth noting that the Arkfeld Pro supports 5V 1A charging and can be fully charged in about two and a half hours.
In addition, a user manual and safety manual are also provided to ensure you have a comprehensive understanding of the use and maintenance of the product.
The stainless steel two-way back clip on the back of the body is secured by two exposed hexagonal screws, which is not easy to disassemble and the clamping force is very tight. With the two-way holding clip, in addition to hanging on the waist trouser pockets, backpacks, but also can be pinned to the brim of the hat as a cap lamp to free your hands.
The dial switch on the neck of the head remains the same, the difference is that it has changed from the previous two options to three, the middle green laser, UV light on the left, white light on the right, the corresponding icons are very graphic. Under different usage scenarios, you can toggle the button to the icon for the function you need to use, and then the round button in the middle is responsible for adjusting the brightness and switching on/off. It's like a remote control, you can switch between the three light sources and adjust the gears (even with gloves on).
About the operation logic, after turning to white light, long press can change the brightness of the gear, quick double click for Turbo, triple click for Strobe. In addition, in order to avoid accidental presses when carrying in backpacks and close to the body, long presses in the off state can also lock the torch. There are two points worth mentioning, one is that the white light and green laser can be turned on at the same time. The other is that in order to save power, you can set the timer switch-off function (the long and short timer time is 9 and 3 minutes respectively, double-click and hold after switching on the power, the light flashes once for the short timer and twice for the long timer).
At the same time, it retains four LED power indicators. If I press the button again, you will see that it is a power-on power indicator with four LED lights. Each LED represents a brightness level, but when the power is lower than 10 %, only the first LED will light up, and it will turn red. There are five battery-level indicators indicated by four LEDs.
The magnetic suction at the end not only can be recharged, but also can be firmly adsorbed on the surface of iron objects, which is convenient to release your hands when lighting. The torch has a built-in temperature sensor that monitors temperature changes in real time and automatically adjusts the output power to suppress overheating when it gets too high, ensuring that the surface temperature of the case is not higher than about 50°C.
If you take a quick look at the head of the lamp, you'll see that it's no different from Arkfeld UV, but a closer look reveals that there's an extra dot in the middle, which is the laser module. In addition, its white light source is still Osram's P9 lamp beads, while the UV lamp is Lumenus SST-10-UV, wavelength of 365-370nm (power 900-560mW). Among them, there are five gears of brightness in white light can be adjusted, Turbo up to 1300 lumens (the previous version of the luminous flux of 1000 lumens), the range of 102 metres. And the common gear high level is 420 lumens.
As we all know, lasers have strong directionality, not only long range, but also high accuracy. It is suitable for many positioning scenarios, such as tactical search, business presentations, on-site teaching, and even as a cat teaser, etc. The laser power of Arkfeld Pro Class1 is ≤0.39mW, which belongs to the safe type of laser, and the white light can be turned on at the same time to assist illumination in the green laser positioning.
Then look at the UV light display effect: the application of ultraviolet light is very broad, daily life to check the authenticity of banknotes, check the surface of the object dust, stains, professional field of criminal investigation, jewellery appreciation. Friends with pets can also use it to see the fungus detection (such as ringworm). Of course, Human and animal body fluids, various plastic products and dust mixed with fluorescents can be stimulated under the UV lamps, emitting fluorescence, and then show themselves.
Finally, let's take a look at the Arkfeld Pro's white light performance: again, there are five lighting levels. For temperature control reasons, the 1300 lm will last for about 4 minutes in the Turbo mode, and then it will drop to 420 lm. A long press under power on will switch between High (420~100 lm), Medium (100 lm), Low (15 lm), and Moonlight (1 lm) modes. It also has good performance in paving, with a large floodlight effect, it can ensure a wide field of vision while the central light spot can also be clearly illuminated to the distance.
In conclusion,Arkfeld Pro Class 1 have a more powerful white and UV light, it's the ideal tool for a variety of scenarios, from professional use to outdoor adventures. When innovation meets practicality, the Arkfeld Pro is born - a must-have for anyone looking for a versatile and reliable EDC light.
Congratulations to the following winners!!
