In a world where versatility and portability are paramount, the Oclip Ultra by Olight emerges as a groundbreaking innovation in compact lighting solutions. Designed to be a pocket-sized powerhouse, this 3-in-1 mini torch combines practicality with cutting-edge technology, making it an indispensable tool for everyday carry (EDC), home use, DIY projects, and specialized tasks. With its ultra-durable construction, adaptive lighting modes, and unmatched convenience, the Oclip Ultra isn’t just a flashlight—it's a miniature masterpiece engineered to illuminate every corner of your life.
Design Philosophy: Small Size, Big Impact
The Oclip Ultra redefines compact lighting with its sleek, minimalist design and OAL™ (Olight Aluminum Alloy) construction. This proprietary material is nearly twice as hard as standard 6061 aluminum, ensuring exceptional resistance to scratches, impacts, and wear. Measuring just 2.24 x 1.11 x 1.10 inches (57 x 28.3 x 27.9 mm) and weighing a mere 1.94 oz (55 g), the Oclip Ultra is small enough to disappear in your pocket yet robust enough to withstand rigorous daily use.
Available in Navy Blue and Olive Green, its timeless aesthetic blends a classic vibe with modern functionality. The body features a patented hinged dust cover tested for 3,000 cycles and an ultra-durable clip rated for 10,000 uses, ensuring longevity even under constant stress.
Triple Lighting Modes: Precision for Every Scenario
What sets the Oclip Ultra apart is its three-in-one lighting system, tailored to tackle diverse tasks with precision:
1. Floodlight (530 Lumens)
Ideal for broad-area illumination, the floodlight casts a wide beam up to 45 meters, perfect for lighting up rooms, workspaces, or outdoor campsites.
2. Spotlight (450 Lumens)
Designed for long-range visibility, the spotlight pierces through darkness with a focused beam reaching 130 meters, making it indispensable for navigation or inspecting distant objects.
3. UV Light (800 mW, 365–370 nm)
Equipped with a high-purity UV LED, this mode excels in specialized applications like detecting counterfeit bills, identifying mineral fluorescence, or verifying cleanliness in healthcare settings.Each mode offers multiple brightness levels and strobe functions, ensuring adaptability to any situation:
Here is the table extracted from the image in a more organized format:
Floodlight Specifications
Mode |
Turbo |
High |
Medium |
Low |
Moon |
Output |
530-300-100 lumens |
300-180-100 lumens |
100 lumens |
10 lumens |
1 lumen |
Runtime |
1+50+30 minutes |
10+80+20 minutes |
3.5 hours |
27 hours |
144 hours |
Throw |
45 meters |
34 meters |
19 meters |
6 meters |
N/A |
Intensity |
505 cd |
289 cd |
91 cd |
9 cd |
N/A |
● White Strobe: 13Hz@530lm/2h
● Signal Strobe: 0.33Hz@530lm/22h
Spotlight Specifications
Mode |
Turbo |
High |
Medium |
Low |
Moon |
Output |
450-270-90 lumens |
270-160-90 lumens |
90 lumens |
9 lumens |
1 lumen |
Runtime |
1+50+30 minutes |
10+80+20 minutes |
3.5 hours |
27 hours |
144 hours |
Throw |
130 meters |
100 meters |
58 meters |
18 meters |
N/A |
Intensity |
4,225 cd |
2,500 cd |
840 cd |
81 cd |
N/A |
● White Strobe: 13Hz@450lm/2h
● Signal Strobe: 0.33Hz@450lm/22h
UV Light Specifications
Output |
800~300mW |
Max Runtime |
3+130 min |
Wavelength |
365~370nm |
Unmatched Durability and Versatility
The Oclip Ultra is built to endure the toughest conditions, backed by rigorous testing and certifications:
● IPX6 Water Resistance: Withstands heavy rain and splashes, even with the dust cover open.
● 1.5-Meter Drop Test: Survives accidental drops onto concrete without compromising functionality.
● ROHS Compliance: Free from hazardous substances, aligning with global environmental standards.
Its versatile attachment options further enhance usability:
● Magnetic Base: Securely attaches to metal surfaces for hands-free use.
● Clip-On Design: Easily fastens to belts, bags, or gear.
● Optional Headband: Converts the Oclip Ultra into a headlamp for tasks requiring both hands.
Intuitive Controls and Smart Features
Navigating the Oclip Ultra's capabilities is effortless, thanks to its user-centric design:
● Mode Selector Switch: Instantly toggle between floodlight, spotlight, and UV modes with a single thumb press.
● Strobe Functions: Choose between 13Hz tactical strobe (for emergencies) or 0.33Hz signal strobe (for long-distance communication).
● Moonlight Mode: Emits a subtle 1-lumen glow for 144 hours, perfect for nighttime navigation without disturbing others.
The USB-C charging port (protected by the hinged dust cover) ensures quick and convenient recharging, while the 580mAh lithium-ion battery delivers reliable power for extended use.
Technical Specifications
Category |
Details |
Dimensions |
2.24 x 1.11 x 1.10 in (57 x 28.3 x 27.9 mm) |
Weight |
1.94 oz (55 g) including battery |
Body Material |
OAL™ (Olight’s proprietary aluminum alloy) |
Battery |
580mAh rechargeable Li-ion (3.7V) |
Charging Time |
~1.5 hours via USB-C |
Water Resistance |
IPX6 (protected against powerful water jets) |
Warranty |
Lifetime in Australia |
Applications: Lighting Up Every Aspect of Life
The Oclip Ultra's adaptability makes it a must-have for countless scenarios:
● Everyday Carry: Compact enough for keychains, yet powerful enough for emergencies.
● Home & DIY: Repair electronics, inspect plumbing, or organize cluttered spaces with precision lighting.
● Outdoor Adventures: Navigate trails, set up camp, or signal for help during emergencies.
● Professional Use: Detect counterfeit currency, inspect HVAC systems, or sanitize surfaces with UV light.
Included and Optional Accessories
Every Oclip Ultra package includes:
● Oclip Ultra x1
● USB-C Charging Cable x1
● User Manual x1
Enhance functionality with optional add-ons:
● Headband Mount: For hands-free illumination during hikes or repairs.
● Magnetic Base: Secures the light to vehicles, tools, or metallic surfaces.
Compliance and Reliability
Tested to ANSI/NEMA FL 1-2019 standards, the Oclip Ultra guarantees accuracy in its performance claims. Its IPX6 rating and ROHS compliance further validate its durability and eco-friendly design.
