Baton 3 Pro Max is a new led torch we released in the first month of the new year in 2023. Do you know what is different about it?
Let's see what's different by comparing the Baton 3 Pro Max with the Baton 3, and the Baton 3 Pro (released in September 2022).
Baton 3 | |||
Release date | 01/2023 | 09/2022 | 03/2021 |
Version source | Baton 3 | S2R Baton II Upgraded | S1R Baton II Upgraded |
Price | £62.99 (30% off for the January 2023 Sale, back to £89.99 after the event) | £69.99 | £ 64.95 |
Form/Size | Medium size | Small /Medium | Small Size (Car key / Zippo Lighter) |
Brightness | 2,500 lumens | 1500 lumens,7900 cd | 1200 lumens |
Beam Distance (m/ft) | 145 m | 175m | 166m/544 |
Max. Runtime (Hours) | 60 days | 120 days | 20 days |
Light Source | LED | LED | LED |
Light Form | Flooder | ||
CCT | Cool White, Neutral White, Warm White | Cool White, Neutral White | Cool White |
Weight (g / oz) | 5.22oz/148g (Including Battery) | 103 g/3.63 oz | 53.0 g /1.87 oz |
Charge Type | MCC 3 Magnetic Charging Cable | Magnetic USB charge cable | MCC 1A Magnetic Charging Cable |
Compatible Batteries | Customized 5000mAh 3.6V 21700 Rechargeable lithium-ion Battery | Customized 3200mAh 3.6V 18650 Rechargeable Lithium-ion Battery | Customized 550mAh 3.7V IMR16340 Battery |
Warranty | Olight’s 5-Year Warranty | Olight’s 5-Year Warranty | Olight’s 5-Year Warranty
1. Upgrade source: Baton 3 Pro Max is the Max version of OLIGHT Baton 3
2. Runtime and Brightness
From the above data it is obvious that the Baton 3 Pro Max has the highest brightness.
Although Baton 3 Pro has a longer running time than Baton 3 Pro Max: 120 days, if you check the detailed parameters, you will find that the lowest brightness of Baton 3 Pro is 0.5 lumens, and the running time is 120 days, while Baton 3 Pro Max's The lowest lighting setting is 1 lumen and the runtime is 60 days.
This way it looks as if the Baton 3 Pro Max's runtime shortcomings can be ignored because nothing is perfect!
If you want to know more about the comparison of Baton Torches, please click here to view:
https://uk.olight.com/blog/baton-3-pro-vs-baton-3-vs-s2r-baton-ii-vs-baton-pro
3. Size: Baton 3 Pro Max vs Baton 3 Pro
The data chart just shows that the Baton 3 Pro Max is a Medium size and the Baton 3 Pro is Small /Medium, you may not really be aware of this comparison, just take a look at this IMAGE.
4. Shake the torch with your hand to show the different power indicators
This is the latest feature of the Baton 3 Pro Max.
Once you give it a shake, an LED light within the switch will illuminate and flash for a second or two letting you know approximately how much battery life is remaining. This was useful as I did not have to turn the light on by activating the switch in order to determine how much power was left.
5. Materials of manufacture: Magnesium Alloy
The Baton 3 Pro Max (Desert Tan model) is Olight's first torch made of Magnesium Alloy, which is lightweight and high strength, offering great impact resistance and heat dissipation characteristics.Olight's First Magnesium Alloy (Desert Tan) torch light!
What is Magnesium Alloy?
Magnesium alloy is the lightest structural metallic material and features high-temperature performance, which makes it ideal for use in the aerospace, mobile devices, bicycles, and in electronic tools. It has also been called "the green structural material of the 21st century", which will be greatly in line with sustainable development appealed to the global community.
It's about 1/4 the density of steel and 2/3 that of aluminum.
Camera chassis of a Samsung NX1, made of magnesium alloy.
The End
The functions of Baton 3 Pro Max are more than that, such as:
● Its sensor function: When the led Torch is turned on and there is an occluded object in front, it will automatically reduce the brightness to keep the Baton 3 Pro Max and the safety of the front object from burning;
● It is still a rechargeable torch;
● It has 3 color temperatures of light sources, of which warm white light is a limited edition in January 2023;
● Although it's a little bigger than the Baton 3 Pro and Baton 3, it's still portable.
Do you still want to know what functions of Baton 3 Pro Max are, please leave a message to tell us.
Giveaway
Olight UK released Baton 3 Pro max purple on the 11th of August!
Comment to tell us what colours and features you like about the Baton 3 Pro Max.
We'll give away a Baton 3 Pro Max Purple 2500 Lumens LED Torch to one randomly selected user in the comments section!
(Event ends at 02:00 19/08).
Congratulations to the following winner who will get a free Baton 3 Pro Max Purple (Worth: £89.99).
